Electric fence energiser
Rufuss
Joined Apr 19, 2022
10
Hi everyone. I’m having capacitor issues on a 12v electric fence energiser. Trying to find out ratings of said caps that are no longer available and matching them is giving me a headache. Some bright spark has glued these blue caps to the board and I’m getting some odd reading in situ. Any ideas on their specs? Not having much luck googling.
Rufuss
Joined Apr 19, 2022
10
Appear to be 3.3uF (400v?) I would replace with WIMA MKP4, these are rated for high voltage, high current.
Are you sure the caps are bad?
No I’m not sure max. But others are bad including this one which I am in the process of replacing.
The blue ones are showing reading of 6.7! Mmmmm
28,075
If you want to get bigger pulses from the same system you need to fill in more of the positions where the blue capacitors are mounted. But then you will need to use a transistor switch with greater current handling capability. So the output can be increased but the effort is not super simple.
The failure that I have come across in fence chargers, with one exception, is a break in the secondary winding connector, usually deep within a winding section. That is easily but not simply repaired bu unwinding the wire onto a spool until the break is reached, patching the break, and then rewinding the wire. This requires a fixture to achieve, not hard to produce, but rather tedious to build.
Once the word gets out that one is able to repair fence chargers there are quite a few folks who want theirs fixed.
I have wondered if an older automotive spark ignition transformer would be effective, but I have never tried to see if it would. That could be an exciting experiment.
MaxHeadRoom
Joined Jul 18, 2013
30,772
I put one together using a modern automotive (waste spark) coil, just a short wire fence to keep deer off the flower beds.
Just Mosfet switching the input side.
28,075
What was the primary voltage that you used? I was going to try using a mains powered fence charger circuit board, so the pulse will probably be about 150 volts to the coil primary, instead of 12 or less.
