efficiency of rectifier.....weird result
youdontknowme
Joined May 30, 2017
15
For my wireless power transfer, the picture shows the secondary side (Receiving).
I'm trying to measure the efficiency of full bridge rectifier by using "eff = (v2*i2) / (v1*i1)" and i'm getting very wrong result.
Voltage is measured with oscilloscope and current with multimeter.
v2 = 17.982v (dc coupled) & i2 = 0.22a (dc) hence p2 = 3.956w
v1 = 32.5v (ac coupled) & i1 = 0.0615a (ac) hence p1 = 1.998w
and eff value would be 1.9799
what am i doing wrong ??
R1 is the resistor load, 83ohm.
L1 is the secondary coil.
for diodes, i'm using 1N5711 schottky diode.
frequency is at 53khz.
thanks
bertus
Joined Apr 5, 2008
22,987
The capacitor C1 will act as a wattless voltage dropper.
The value will influence the output voltage.
Bertus
BobTPH
Joined Jun 5, 2013
11,609
This is how over unity devices created: misunderstanding how AC power is calculated. You cannot get average power by multiplying average voltage by average current. You have to integrate the product over the entire period. The phase of the two makes the difference.
Bob
DickCappels
Joined Aug 21, 2008
10,662
Do you suppose the fact that a 1N5711 is only rated at 15 ma continuous current (or average current in your case) has anything to do with the problem?
Consider the 1N5819, it was designed for the kind of circuit you have.
