This wont reqquire a bistable circuit to operate.just the floatswitc and the relay mechanism..You could go to a simple switch mechanism as shown below.
The float, maybe a bottle with some water in it to weigh it down a bit, and the weight need to be heavy enough to operate the switch.
The float cord passes through a ring on the end of the switch arm and the clamps on the cord set the on and off levels.
I have seen this in use before. The hardest part is making an arm to suit an available switch.
Also ensure end stops are there to prevent the switch getting damaged if someone pulls on the cord.
An added benefit of this is you can see the tank level by the position of the weight.
'll try thiss firstView attachment 119923 Something like this be easy to do
actually want it to pump when too low and to stop when too high...I already implemented a bistable multivibrator(i.e with the circuit diagram i wasgiven. It actually works just fine..new to this circuit and i dont know what the float switch would beswitching..cause thhe circuit already works automatically by itsself..but even with that circuit i cant put those sensors (copper wire) into water..its absolutey not safe..i still wanted to know if the float switch can carry out the operation on its own withottheciCutI'm wondering: Do you want to pump water INTO the tank when it's too low? Or do you want to pump water OUT of the tank when it's too high?
If all you want to do is turn a pump on when the water is too high - that's very easy. Any electronic circuit as you've been shown already can turn the pump on when the water is too high and shut off when the water no longer is too high. But that precludes a low limit. Here's where a float switch would be best suited. An old toilet ball float on a long rod connected to a hinge with a microswitch can turn the pump on when it rises too high. As the water drops there will be some hysteresis to the pump and the motor won't short cycle every 10 seconds.
On the other hand, a low level system detect will require turning the pump on at a certain level and shutting off when it reaches a high limit level. A bit more complex than the toilet float system because the system has to wait till a specific (low) level is reached. Then when the pump has pumped sufficient water into the tank it needs to shut off.
I've seen sump pumps that are meant to drain a pit that consist of a float that rides up and down a rod. When the float goes high enough it flips on a switch and runs the pump. The pump continues running until the float drops low enough that the switch is then pulled off.
Just by way of example, here's a link: https://www.amazon.com/Superior-Pum...8&qid=1486316891&sr=8-6&keywords=float+switch
You can make your own easy enough using parts you probably have laying around the house. A long steel rod and a float to travel up and down. When the float reaches the bottom of the rod it shuts the pump off. When it rises to the top it turns the pump on. This sort of system can work either way, turning a pump ON when the water is too low and off when it's high enough.
To better understand where you're going with this please define how you want the system to work. Pump on when too high? Or pump on when too low?
I'm wondering why you can't put copper wires into the water. All they do is provide minimal current to the 555 so that it can trigger and shut down the pump. But if you wanted to use a float and switch - yes, you can do that as well. I'll bang out a drawing in a few minutes and post it.i cant put those sensors (copper wire) into water..its absolutey not safe.
If it works then why do you want to fix it?It actually works just fine.
I was just looking at the distance btw the sensors and the circuit is about 40m..wont there be too much loss.If it works then why do you want to fix it?
Yeah..now i get..but coppper has some after effect in water like rusting..I'm wondering why you can't put copper wires into the water. All they do is provide minimal current to the 555 so that it can trigger and shut down the pump. But if you wanted to use a float and switch - yes, you can do that as well. I'll bang out a drawing in a few minutes and post it.
OK, here's ONE solution. Keep in mind that if your switch fails to shut the pump off it will continue to run and over flow the tank. Consider building in some safety backups against over filling the tank.
Here in America we have a lot of copper plumbing. Copper kills microbes, so our water gets a little help that way. As for rusting - or tarnishing - it has never been a problem before.coppper has some after effect in water like rusting.
40 meters is a bit far. I really don't know if you will have issues with your system. But I recall you said it works fine. If you mean as a test bench setup - OK. But if you have field tested it and it worked then I don't see any problem. And if you're using 12 volts as a supply for your electronics, I don't think you'll run into too much trouble with the distance, but that's just a hazarded guess. I really can't say for sure. However, using a switch (as in my drawing) to operate a relay, you can have plenty of power (at 12 volts) to drive a relay to actuate the pump.the distance btw the sensors and the circuit is about 40m..wont there be too much loss.
Ok..i'll put that into practice and post a feedback..can I be ur student?Here in America we have a lot of copper plumbing. Copper kills microbes, so our water gets a little help that way. As for rusting - or tarnishing - it has never been a problem before.
If you can place the sensor and circuit close by the tank and have the output operate the relay then the power the relay is controlling to run the pump - 40 meters shouldn't present that much concern for line loss. It'll probably work.
Really don't mind. Thats How u know good engineers..#confusion..am i admitted?If you like learning confusion. I'll be glad to help when I can but there are a lot better teachers here than me. I'm OK with basics. But yesterday I spent a couple hours trying to figure out how my math ended up being wrong. I'm not good with decimal figures. But I'll also let you know when I don't have an answer. I won't try to BS you.
It was a missquote when i said I couldnt afford a float switch..they just dont sell in my area...I do know copper wires are good conductors but copper wires also rust when they come in contact with water time to time...I'm sorry, but there seems to be some disconnect between our world here in the USA, and yours, and I suspect language must be a factor.
If you cannot afford a float switch, I don't know how you can afford a tank, a pump, electricity, a 555, a soldering iron, solder, wire, or water. If you know what a multivibrator is, or a bistable circuit, how can you not realize that copper oxides are good conductors, and those precise characteristics are why copper is the preferred conductive material for the vast majority of electrical devices on this planet?
You can make your own float switch from items we find littering our streets here in the US (and cities in the 4 continents I've been to).
If your sensors are 40m from the circuit, they are not part of your circuit, which may well be one of your problems.
If you have something that works fine, use it. You might tell us what it is, and does, but no need, really.
Was asked to use a scr (bt106) in plaace of the relay..how do I connect it to switch the pumpSure. Ask anything you like.
I'm going to go get ready for Super Bowl 51. Gotta grab some beer and a Chicago style meat lovers pizza.
