Effect of IGBT on load side of Boost Converter
AF_Maxwell
Joined Dec 12, 2018
36
I'm seeing some unexpected behaviour and I'm not sure what's causing it.
I'm charging up 50V into a boost converter and then when discharging it using a thyristor, there is no issue here. When attempting to do the same with an IGBT, i.e. thyristor disconnected and IGBT connected, the boost converter has difficulty charging up to 50V. In fact it will only charge to half of that.
Exactly what could be the difference between having a thyristor in the off position connected as an output path for a capacitor bank and an IGBT in the off position connected as an output path for a capacitor bank?
The only thing I can imagine is that the IGBT is facilitating current leakage out of the capacitor even while the IGBT is off, but what would be causing this?
