ECG Simulator - Breadboard Version
giovannelucas_
Joined Jan 5, 2023
39
Hi everyone,
I'm currently working on an ECG Simulator from SW website. It uses a 555 timer to generate the signal.
What I'm trying to do is to read the signal with an ESP32 through an non-inverting amplifier circuit to bring up the voltage to around 2.8V.
I used D4 which is an ADC.
However, when I open the serial plotter the signal is very distorted.
Is the ESP32 able to read negative voltages? Because as shown in the picture there are negative voltages.
I used an op-amp with a gain of 3.3 using a 33k and a 10k resistor and a TL071.
As said in the datasheet the voltage difference between V+ and V- should be at least 10V, I used a 12V power supply.
Did I do something wrong or is there an error somewhere?
I also simulated the generator circuit and gave a normal signal. I also amplifier the signal and it looked fine on LTSpice.
dl324
Joined Mar 30, 2015
18,432
No.
Your simulation is meaningless. You say you're using a 12V supply, but in LTspice, you're using 5V and you're using LM741 which are useless with a 5V supply.
The picture of your breadboard is equally useless.
