Greetings,
I'm working on an ECG circuit ( schematic below), I replaced the electrodes with pennies and gator clips. I followed the schematics, powered the circuit, then I attempted to test the cicruit response. Whenever I touch the left and right chest electrodes or connect them to different parts of the body together the LED (D8) is always on. I used a soundcard scope (https://www.zeitnitz.eu/scope_en) to see the ECG signal, it gave me a a sawtooth waveform that looks like a one generated from 555 timer mirrored upside down, I tried adjusting RV3 many times and measuring output voltage of the AD620, I end up with with results between 1.5v on minimum RV3 and 4.20v on maximum.
I doubt this circuit needs a dual supply instead of single supply, but i dont know why its not giving a proper response, it should be dynamic since body doesn't have the same potential difference at every two points, but this signal looks static with any input I give.
Thank you.
Thank you.
