Easy eda help
gaber2611
Joined Mar 14, 2013
331
Hello
I am new to easy eda
Here is what I've done by schematic, while I work on pcb footprints I found that I need to. Complete this schematic
IMG_20241221_213549.jpghow I connect this mosfet drain to a point or pad where in real the wire will be soldered at this point?
I need all mosfet drains to be connected to seperate pad
And the other pad to common Vcc,
Also, my Vcc and ground terminals are right?
Please advice
panic mode
Joined Oct 10, 2011
5,321
if there is going to be a wire connecting to it, decide how that wire will be connected to PCB. normally I would use a connector or terminal block. but, if wire is t be soldered, use a pad... preferably through hole (mechanically more robust).
