earth battery powered joule thief
Status
Not open for further replies.
electro01
Joined Jan 14, 2013
9
I have constructed an earth battery and a joule thief which seems to fire up the Jt. My earth battery ouput is around .8vdc. My Jt. lights up with a
unbelievable voltage of around .5vdc with a LARGE led. Can I feed a
voltage doubler with the Jt? I messed up my earlier post with insufficient
details. Sorry. I would like to pick up the voltage to about 1.85 volts with
this approach but unsure which diodes and caps to pick for my voltage
doubler. Is this even possible? I need about 1 amp @ 1.85 volts if
possible. What do you think? I am trying to understand this stuff the best
I can and need a little help if you can. Thanks so much... This is a hugely
important project for everybody. I plan to post schematics when finished.
It's amazing what all you can do with a measly 1.85 volts!!
t06afre
Joined May 11, 2009
5,934
I need about 1 amp @ 1.85 volts if possible. What do you think?
It is Ok to want to explore. But to be honest. I think you are on path that will lead you into nothing. You can not create energy out of nothing. But that is what you are trying to do here.
18,162
Well, this isn't over-unity. It's quite real, if impractical. Could be fun for a science fair project though. It is NOT "a hugely
important project for everybody".
#12
Make 2 earth batteries and put them in series to get 1.6 volts?
Use really large metal plates to get a whole amp of current.
You can't amplify amps without losing voltage proportionately.
thatoneguy
Joined Feb 19, 2009
6,359
An amp is a lot of current.
You actually are building an "Earth Cell", not a battery. You need to add more plates for it to be a battery.
You could do better with a bunch of potato cells in series/parallel, and the result would be much more portable. Need zinc and copper for electrodes.
Series (connecting + of one to - of next) increases voltage.
Parallel (Connecting + to + and - to - of each) increases current.
Putting 3 in series and maybe 50 in parallel (150 total) might get you close. The world record for potato battery voltage is 583.1 Volts @ a few mA. Made with 1,000 Velox variety potatoes.
Status
