Earbuds charger makes a high pitched noise after throwing the swollen battery. Is it safe?
amateur_css
Joined Aug 29, 2024
I throw away the swollen battery of my xiaomi earbuds2 but I wanted to use it without the case battery. It doesent charge without battery, so I connected the battery protection board to the board. It worked, but it makes a loud high pitched noise and kinda concerns me. Is it safe? And how do I reduce that noise?WhatsApp Image 2024-08-29 at 20.22.41.jpeg
27,495
It may not be safe because the voltage may be to high. Adding a DC filter is not terribly complex, but the very first thing is to measure the voltage because it may be excessive and cause damage or destruction.
amateur_css
Joined Aug 29, 2024
Earbuds are getting 5.2 volts. It looks not that bad I guess. Only the noise concerning me.
amateur_css
Joined Aug 29, 2024
That battery did provide a good noise filter so now you will need to add some in-line noise filtering to remove that high pitched noise.
Uhm, I obviously don't know how to do it. Can you provide some schematics? I have a solder and bunch of electronics so I think I can buit one. Is it something like that? (Found it online)
