Duobinary data representation
Maria98
Joined Nov 24, 2023
hi
How does duobinary sequence has double spectral efficiency compared to binary data while having a one-to-one correspondence with the simple binary stream of data?
Ya’akov
Joined Jan 27, 2019
10,295
hi
It doesn't. Duobinary encoding takes advantage of predictable ISI (Inter Symbol Interference) to recover the original data stream. Any time you transmit N bits per second, the Nyquist demands you use a bit rate of N/2Hz—if you want to avoid ISI. But if you can tolerate some ISI because you can remove it by clever filtering, that limit—while it still exists—doesn't apply.
Your thread has been moved to the Homework Help forum in accordance with the rules of AAC requiring any coursework related questions to be posted there. Members are required to avoid complete answers and assist with the student's efforts instead.
