May I see the similar graph where "vtmp" is connected to input terminal(+) and "Vref" is connected to input terminal(-) of the AD620 IC chip?
The graph came from transient analysis is it?
May I know what's the explanation behind the "D1 LED" and "D2 LED" lighting up differently when the LM35 is below 0.5V and above 0.5V?
hi Isaac,
The Gain cannot be infinite, look at page #7 of this PDF, to show the gain limits.
The AD620 or any INA is not suitable for use as a Comparator.
E
The AD620 is acting as a Comparator and the Vout switches over at the Vref versus Vtemperature voltage point.May I know what's the explanation behind the "D1 LED" and "D2 LED" lighting up differently when the LM35 is below 0.5V and above 0.5V?
I considered it the practical solution.4. For the AD620 IC at the above circuit, I saw that the Rg pins are connected to 10ohm resistor. Is there a reason? the difference between shorting it and connecting a 10 ohm resistor?
Yes.2. When the LM35 is above 0.5V, the Vo is in negative value, thus not able to overcome the forward voltage of the "LED D2" and not lighting it up. During this period, the voltage of 5V connected in series to "LED D1" is lighting it up.
hi Isaac,
Check out Post #20 for a LTSpice simulation result with a AD620 and LM35
Yes.
Note: the 0.5V for Vref represents a temperature of +50Cdeg, ie: 10mV/Degree Centigrade at the LM35
E
May I know how connecting a 10 ohm resistor to Rg pin 1 & pin 8 would be a practical solution?hi Isaac,
Yes.
E
Hi Isaac,May I know how connecting a 10 ohm resistor to Rg pin 1 & pin 8 would be a practical solution?
If i refer to the gain equation and the maximum gain limit given in the AD620 datasheet:Hi Isaac,
What do think the value should and why.?
E
My laboratory is only able to provide the smallest resistor value of 10ohm, unfortunately. So I'll stick with 10 ohm resistor as your previous LTspice simulation circuit.hi Isaac,
With a Rg of 10 ohms and the Gain Equation, that is a Gain = 49400R/10R = 4940.
Which is roughly half the maximum gain stated in your second data clip of 10,000 and 5 times greater than the first data clip of 1000 maximum.
If you are confident that the second link is correct, you could use a 5R for RG, which gives a gain of ~10,000, attached simulation.
I have increased the LED resistors for the LED's to 1k5, this will give an LED current of approx 10mA which is OK.
E
hi,How can I control the current value passing through the two LEDs? Is it through connecting a different value resistor? Is there a way to calculate? Ohms Law?
Hi, I'm currently enrolled in BSc in Electrical & Electronics Engineering, 2nd year of studies.hi,
May I ask what technical course you are enrolled on and at what year level you are studying.?
I ask this in order to know at what level I have to explain my help.
Calculating the current through a Series resistor and LED are very basic equations.
E
Hi Isaac,If I were to calculate the current passing through the resistor, R1 would be:
V = IR
The Vout terminal of the AD620 can either Source or Sink current at the junction of the LED's/Resistors network.- V = ? [AD620 output after differing the voltage value between (+) & (-) terminal] *I dont get this part*
- I = ?[I am finding this value]
- R = 1k ohm
Hi Eric, I am not clear regarding this part. I am trying to understand how the AD620's Vo of "10.2V" & "-5.22V" from my simulation circuit came to be.The Vout terminal of the AD620 can either Source or Sink current at the junction of the LED's/Resistors network.
The AD620 Source/Sink current has to be considered in your calculations as well as the current from the +5V voltage source.
Hi Isaac,My current understanding is that because the Rg inserted to AD620 is 10ohm. The Vo of AD620 is saturated towards the supply voltage(+15V & -15V). From my circuit, I'm getting +13.5V & -13.7V which I can consider theoretically correct?
Hi Eric,Hi Isaac,
The AD620 is not a Rail to Rail output, it will saturate at approx Vout = +/-Vsupply -1.5V.
E
Clip from datasheet.
May I ask if my calculation for the I(R4) and I(R3) is correct?Is this the correct method in calculating the current flowing through R4 & R3?
Hi Eric,The Vout terminal of the AD620 can either Source or Sink current at the junction of the LED's/Resistors network.
Application Design Guidelines for LM339, LM393, TL331 Comparators | Datasheets, Manuals & Parts Identification | 0 | |
| M | RF Dummy Load | Wireless & RF Design | 10 | |
PCB Manufacturing — Complete Beginner’s Guide | PCB Layout , EDA & Simulations | 5 |
