dumb voltage question
shortbus
Joined Sep 30, 2009
10,050
OK, you guy's know I ask dumb questions, so here's my latest. If you have two separate voltage sources, A and B that are joined at common/ground, and at positive in a diode "or" situation what is the voltage coming out of the "or" to the rest of the circuit? Example -
Source A, +10VDC, to diode A, to circuit
Source B, +20VDC to diode B, to same circuit
Sources A and B negative pole tied together as common ground
What would the voltage be going into the circuit?
32,845
Things are SO much better with a diagram, even just something quick in Paint.
Is this what you have in mind?
Assuming diodes with a forward voltage of Vd, then if the left diode is conducting
Vba = Vd
while if the right diode is conducting
Vca = Vd
We can have Vba or Vca be less than Vd, that just means the diode is cutoff. But we can't have either of them be greater than Vd otherwise the diode is smoked.
Since we know that
Vba = Vb - Va = 10V - Va
and
Vca = Vc - Va = 20V - Va
we can combine these to get
Va = 10V - Vba = 20V - Vca
and this gives us
Vca = Vba + 10V
This tells us that Vca always has move forward voltage across it that Vba, which means that if Vca = Vd then Vba = 10V+Vd which would smoke it. Since we know that the highest diode voltage is Vd, that must therefore be Vca. Thus we know that
Vca = Vd
and
Vba = Vca - 10V = Vd - 10V
Either of these is enough to give us the voltage at A.
Va = Vb - Vba = 10V - (Vd - 10V) = 20V - Vd
or
Va = Vc - Vca = 20V - Vd
MikeML
5,444
Load Voltage and Current vs load Resistance:
Diodes shown are only rated for 1A continuous.
Schottky diodes will have a lower forward drop.
shortbus
Joined Sep 30, 2009
10,050
Thanks guys. one reason I asked is from a thread over at ETO where they were talking about "stacking voltages". A single supply voltage that needed a periodical short time higher voltage, and two supplies were used together to get the higher voltage. Guess I should have asked over there how they did it, and will. Just seem to get better answers here. :)
30,661
Stacking one supply on another implies something different than both using the same common reference point.
shortbus
Joined Sep 30, 2009
10,050
Stacking one supply on another implies something different that both using the same common reference point.
Why? They would/do need a common somewhere in the circuit, or they are just two circuits. Again this is for my EDM power supply. It needs ~100VDC continuous with a periodic spike up to ~170VDC. So 100VDC with a stacked 70VDC periodic.
So how would the extra voltage be "stacked" on the backround voltage?
32,845
You have a 100VDC source in series with a 70V pulsed source. Schematically, they would (could) appear to be stacked on top of each other, hence the name.
shortbus
Joined Sep 30, 2009
10,050
Not trying to be confrontational, but to understand this.
In my first post I used lower voltages as an example, and was told it wouldn't work. So if my example was wrong how would it be done? Doesn't the need to be some diode involved to keep the voltages separated when the 70VDC is not pulsed on? The pulse only needs to be for ~2 or 3 microseconds.
30,661
To me stacking supplies means one on top of the other, IOW the zero ref for one is connected to the plus of the other, one on top of the other.
Whereas you mention in your OP that they share the same common, which is not the same thing.
In general for two voltages sharing the same common, the higher one will reverse bias the second.
32,845
But in your first post you didn't mention that they were stacked. In fact, just the opposite in that you specifically stated that they shared a common ground. You REALLY need to provide some kind of a drawing of what you have in mind.
