Dual Supply or single supply for analog SPDT switch
anand3001
Joined Sep 25, 2009
8
Hello all,
I am designing a signal conditioning circuit for a load cell.
I need to offer programmable gain for the input stage instrumentation amplifier. Its a standard instrumentation amplifier with the gain equation given by G = 1 + (50000/Rg). The input to the instrumentation amp is a bipolar differential +/- 10 mV signal. The gains are in the region of 100 to 400. So the voltage at the output of the instrumentation amplifier is in the range of 0 to +/- 1V or +/-4V. But in reality the signal will be unipolar in nature due to the fact that the dead weight of the weighing pan will always place the signal in the positive quadrant.
My question is Can I use a single supply analog switch for the gain selection or do I need to use a dual supply one? Any help would be highly appreciated.
I am attaching an image file showing the proposed scheme for the gain selection for the instrumentation amplifier.
I also have downstream amplifiers that boost the signal to about 7.5 V. Would the mux/switch used for the gain selection for the downstream amp have to be dual supply or single supply and what voltage?
regards
Anand
OBW0549
Joined Mar 2, 2015
3,565
According to the data sheet, the ADG1409 can be operated from either a single supply or dual supplies.
You've got a more serious issue with this circuit, though: the ON resistance of your analog switch, which can vary from unit to unit and change significantly with temperature, is in series with whichever gain setting resistor is currently selected. This will result in a gain error, especially at the highest gain where your gain setting resistor is only 125Ω or so.
ci139
Joined Jul 11, 2016
2,033
soyez
Joined Aug 17, 2020
51
Hello all,
regards
Anand
it should be dual supply and voltage of 50V will go better
anand3001
Joined Sep 25, 2009
8
Yes sir you are right about that. With the instrumentation amplifier I want to place the signal within a general window. The rest I intend to adjust with a calibration circuit. There are other analog switches with RDs on as low as 0.5 Ohm. But they are more expensive and will shoot up the BOM. So its a touch choice. I selected a dual supply switch in the ADG 1409 but as an after thought wondered if a single supply switch would work... In that case there are low RDs ON resistance switches that are cheaper. Also I was considering the fact that the final signal will be uni polar after the weighing pan is in place... I thought I might just have a chance to work with a single supply switch. Would be interested to know your thoughts. Thanks for the reply.
OBW0549
Joined Mar 2, 2015
3,565
Watch out: since the analog switch ON resistance is temperature-sensitive, that could complicate calibration.
I don't see why a single-supply switch wouldn't work, provided its specs all line up with what you need.
