Driver circuit for solenoid valves
eetech00
Joined Jun 8, 2013
4,724
Will IRL540 switch directly solenoid? or else need other circuitry with IRL540?
Will you point out required MOSFET driver because there are many available but looking which one is suitable for the requirement ?
Hi
I didn’t see where anyone asked this, but is the solenoid an AC type or DC type solenoid?
eT
bertus
Joined Apr 5, 2008
23,000
As stated on the give page, the valve can make 5 cycles a second.
1 cycle will be 200 mS, so 100 mS on and 100 mS off.
You can make pulses of 100 mS with it.
Bertus
38,764
The rated current of the diode must be higher as the coil current of the solenoid.
Since the diode only carries the current for a short period of time, the surge current rating of the diode can be used to size the diode, unless the solenoid is being very rapidly turned on and off.
But a diode rated near the solenoid current would be a good conservative selection.
daljeet795
Joined Jul 2, 2018
295
The 1N4007 can be used as back emf diode.
Bertus
aeroflex solenoid valve v4-08
I am trying to get current rating for aeroflex solenoid valve v4-08 DC but I didn't see the current specification for aeroflex solenoid valve v4-08 on my search
