drive motor while switch is pressed
skyr6546
Joined Mar 22, 2019
73
I am trying to write program to drive motor while switch is pressed but if the switch is not pressed. don't turn motor instead sound buzzer for few seconds
Code:
//8051 and keil compiler
#include <REG51.h>
sbit Switch   = P0^1;    //  switch connected to P0.1
sbit Motor    = P2^0;    // motor  connected to p2.0
sbit Buzzer   = P2^0;    // Buzzer connected to p2.0
#define  ON    1
#define  OFF   0
/* This is delay function */
void Delay (unsigned int n)
    unsigned int i;
  for  (i = 0; i <n; i++);
void main (void)
        while(1)
             while (Switch == ON)      // switch is pressed
                   Motor = ON;         // Turn ON Motor
                              Buzzer = ON;
                                Delay(5000);
                                Buzzer = OFF;
Is there any logic error in my code that may be improved ?
AlbertHall
Joined Jun 4, 2014
12,651
As it is, consider what will happen when the switch is not pressed. The loop will always enter the 'buzzer on, delay, buzzer off' code so you will get almost continuous buzzer sound. You want the buzzer to sound only once when the button is released. You could use a boolean variable which is set if the button is pressed, then only run the buzzer code if this variable is set and then clear it.
skyr6546
Joined Mar 22, 2019
73
Hi @AlbertHall
I am using keil compiler I searched for boolean data type but I don't understand how to use boolean data type in keil compiler
skyr6546
Joined Mar 22, 2019
73
You could achieve the same by setting a variable to '0' and '1'.
I am not familiar with the keil compiler. It seems you need to include <stdbool.h>.
http://www.keil.com/support/man/docs/armcc/armcc_chr1359124241645.htm
okay I am trying here
Code:
#include <REG51.h>
#define  ON    1
#define  OFF   0
    unsigned int i;
void main (void)
     int boolean_variable;
        while(1)
                                    boolean_variable = 1;
                       if (boolean_variable == 1 )
                                Buzzer = ON;
                                  Delay(5000);
                                 Buzzer = OFF;
                             boolean_variable = 0;
AlbertHall
Joined Jun 4, 2014
12,651
'boolean_variable = 0' needs to be inside the braces not outside.
'Motor = ON' turns on the motor. It will then stay on until 'Motor = OFF' which should be in the 'switch not pressed' section.
skyr6546
Joined Mar 22, 2019
73
I hope this is okay
Code:
#include <REG51.h>
#define  ON    1
#define  OFF   0
    unsigned int i;
void main (void)
        while(1)
                                  Motor = OFF;
                                Buzzer = ON;
                                  Delay(5000);
                                 Buzzer = OFF;
