Drill size for 5/16" tap?
OBW0549
Joined Mar 2, 2015
3,565
Looking at the "Tap Drill Chart" section at the bottom, they recommend an "F" drill for a 5/16"-18 fastener. Then, looking up above at the "Decimal Equivalent Chart" section, an "F" drill measures 0.257", about halfway between 1/4" and 17/64".
I'd try the 17/64" bit first on a piece of scrap stock and make sure it's not too loose. If it is, try the 1/4" bit and make sure it's not too tight. If it is, I'd guess you'll just have to find an "F" bit.
30,766
Unfortunately they do not include a tap set for each size, when tapping you need to use a taper tap first followed by a second and plug or bottoming tap, the latter is needed if the hole is blind and not a through hole.
If just thin material, a taper alone will work.
Don't expect too much for $10.00
BTW, for aluminum, use kerosene or WD-40 for a tapping lubricant.
spinnaker
Joined Oct 29, 2009
7,830
So I can't do it with what I have?
30,766
Yes, but with those taps it is a little harder to start the thread, sometimes a slightly larger hole will be a work-around.
If thin sheet, you may be OK, although with sheet you need a fine thread tap.
The one shown appear coarse thread.
spinnaker
Joined Oct 29, 2009
7,830
Maybe I should explain what I am trying to do and I might get better ways to do it. I am trying to create a clamp jig for my cheap CNC machine.
I plan to have 2 rails that run the length of the X-axis.
I will make 2 clamps that will ride on the x-axis rails. I will likely also place a plate on this clamps that will hold down the PCB. I need to have a way to secure the clamps to the X-Axis rails but make the clamps adjustable along the rails. My plan was to drill holes all along the rails and move the clamps as needed. If there is a better way to hold down the clamps, I am open to suggestions.
#12
3/4?:eek:
If it was 0.090, I would just wallow the hole with a 1/4 bit. What's the problem with 0.007 inches in aluminum?
At 3/4 inches deep, you might find a 1/4" hole fights you all the way down, and I just hate snapping off a tap in a hole.:(
You might get away with it if you clear the chips every three turns...and you might need the right drill bit.
30,766
One place that has some nice work holding devices and general hardware for CNC etc, it Misumi USA, the free Cat. is worth it just a s a reference and to get idea's from.
They have Toggle clamps that may work.
spinnaker
Joined Oct 29, 2009
7,830
3/4?:eek:
Won't go all the way. 1/2" at the most. They will be blind holes.
