Drill battery pack - extra terminal
Nathan Hale
Joined Oct 28, 2011
159
Hello All! Hope all is well with everyone!
I recently opened up a old cordless drill that was lying around for years. I stopped using it because it just wouldn't charge up.
I noticed that the battery pack inside had 3 wires instead of 2 wires, coming out of it.
The wires were going from the battery pack, in to the drill trigger mechanism as seen in the pictures.
Can some one please tell me what the purpose of the 3rd terminal on the battery pack is? The third terminal is marked with a red arrow and is much LESS wider than the other 2 terminals. The third terminal had a white wire coming out of it.
Thank you for you replies!
WhatsApp Image 2020-05-07 at 5.10.16 PM (1).jpegWhatsApp Image 2020-05-07 at 5.10.16 PM (2).jpegWhatsApp Image 2020-05-07 at 5.10.16 PM.jpeg
35,299
The third terminal is likely a connection to a temperature sensor.
The temperature is monitored during charging to prevent overcharging which will destroy the batteries.
Nathan Hale
Joined Oct 28, 2011
159
Really?! You mean I could probably salvage a temp sensor from that black box?!!! I am opening that thing, right now!! Thanks for your reply!!
