Dragon Board 12Plus- HCS12 micro- KeyPad and 7Segment LED
Lohitha Wickramasinghe
Joined Apr 20, 2017
I'm trying to display two digits on the 7 segment LED display for the project I'm doing. So far I can only display one digit and when I press the second button the first number completely erases and display the 2nd digit. Here is the code I wrote so far. The function "ScanKeyPad()" outputs 0-15 which corresponds to the keypad number. So basically when I click 4 and 8 it should display 48. Below is the C program.
Code:
while(1)
        key = ScanKeyPad();
        if(key != 16) // If a key is pressed
        hold_var = key ; // holds (remember) the value of the key
        // this sequence shows the value of the key that is pressed, in 2 digits
        for (i=0;i<20;i++){
        PTP = 0x0f;
        PTB = SegPat[hold_var/10];
        PTP &= ~0x04;
        delayby1ms(10);
        PTP = 0x0f;
        PTB = SegPat[hold_var%10];
        PTP &= ~0x08;
        delayby1ms(10);
      // If a new key is not pressed (DEFAULT)
        if(key = 16)// this sequence keeps showing the same number if a new key is not pressed
        PTP = 0x0f;
        PTP &= ~0x04;
        delayby1ms(10);
        PTP = 0x0f;
        PTP &= ~0x08;
        delayby1ms(10);
ErnieM
Joined Apr 24, 2011
8,415
I see some rudimentary code to provide some key debouncing, but I wonder what happens when you either press a key very quickly, or leave it down for several seconds.
Also there are a lot of calculation just to save a memory position you don't really save anyway. I'd hold the keys in two unsigned char variables:
Code:
unsigned char Digit_0 = 0;
unsigned char Digit_1 = 0;
int Digit_Value = 0;
if (key != 16)
    Digit_1 = Digit_0;
    Digit_0 = key;
    Digit_Value = Digit_1 * 10 + Digit_0;    // if you need to use this elsewhere
then pass Digit_0 or Digit_1 to the SegPat routine.
