Hello, this is my first time designing a pcb and also my first time using the AVR dragon. I'm trying to program an ATUC256L3U microcontroller (with LED blinky) using aWire. I've been powering the pcb with a pc power supply at ~3.4V. The ground is connected to both the dragon and the PSU (maybe causing problems?). On the standard aWire header I have pin 1 being the MCU n_reset (no 47k pull-up currently), pin 2 being 3.3V for the board and pin 6 being ground for the PSU with the dragon ground being connected elsewhere on the ground plane. I get this error every time and I have no idea what it means. Also, as a side question, why is the target voltage as reported by Atmel Studio 7 is almost always about 0.9V higher then the voltage from the PSU when measured with a multi-meter?
Thanks for reading,
Avi
Thanks for reading,
Avi
