Downgrade AMP
Mohammad Mohiuddin
Joined Feb 7, 2017
8
I have transformer which input AC 220V (50-60Hz) and output voltage is 48V DC 130 Amp. Could I use this transformer in my 5V DC 2Amp device? For your information I use another circuit for downgrade voltage from 48V to 5V DC. I can't downgrade the Amp. Have there any option to downgrade this 130 Amp to 2 Amp?
Dodgydave
Joined Jun 22, 2012
11,395
Yes you can downgrade the voltage to 5V using a regulator or buck converter like L7987, the current will limit itself.
Mohammad Mohiuddin
Joined Feb 7, 2017
8
I am already downgrade my voltage 48V DC to 5V DC. But I am aware of Amperage (130A). Where my devices need 5V DC and 2A. With downgrading the voltage what happen the current (Amperage)?
34,815
Apply Ohm's Law:
I = V/R
V = 5V
What is the resistance of the load?
If the resistance is 2.5Ω
I = 5V/2.5Ω = 2A
That is the amount of current the 5V power supply will have to deliver. The 48V supply will adjust its current automatically to provide this amount of power, with its efficiency taken into consideration.
Mohammad Mohiuddin
Joined Feb 7, 2017
8
Apply Ohm's Law:
I = V/R
V = 5V
I = 5V/2.5Ω = 2A
BobTPH
Joined Jun 5, 2013
11,516
48V and 130A? I doubt it. You could barely lift that transformer.
Reducing the voltage from 48V to 5V is not efficient. Find a more appropriate transformer.
Bob
Mohammad Mohiuddin
Joined Feb 7, 2017
8
Thank you Bob. This is my Sony HiFi 200watt sound system. I found there is a big and quality transformer (made in Japan). And I have 30 pcs (media converter) device which need 5 VDC and 2 Amp. Now I use separate adapter for each device. But I want to use a single AC input (200~240 VAC, 50~60 Hrtz) and I want to use >50pcs (media converter) device. I already make a drop down 48 VAC to 5 VDC circuit. But I am confuse to using this output current. If you sure that this high Amperage not effect any process, just let me know this.
frank55 General Electronics Chat 3
Similar threads
CPU downgrade?
