don't know how to read the log chart
sumalama
Joined Nov 19, 2014
4
can anybody tell me how much value is the red line (point on x axis) is indicating in the figure attached?
its confusing me.
thanks
jpanhalt
Joined Jan 18, 2008
11,087
It looks to me like the line is about half way between \( 1X10^{^{-4}}\) and \(2X10^{^{-4}}\) . Since on a log chart, half way is about 3, not 5 (i.e., 10^1/2 =3.16...), I would say the line is \(1.3X10^{^{-4}}\).
What is the "correct" answer?
John
jpanhalt
Joined Jan 18, 2008
11,087
I thought it was homework. The chart reads left to right, the value has to be less than 10^-3.
John
Edit: If you can find an old slide rule at a museum, you can see what I mean.
18,155
Your's is. One could quibble over the last significant figure, but I agree with your estimate.
jpanhalt
Joined Jan 18, 2008
11,087
Well, since the mark was in crayon, I didn't try to be too accurate. Besides, it is not often today that you can go back to your old Pickett skills.
In reality, my intent was to help the TS analyze the question.
John
35,140
So it is somewhere between 0.0001 and 0.001
The next mark to the right represents 0.0002
Hence it is somewhere between 0.0001 and 0.0002
Now look at a slide rule which uses a log scale:
The cursor is positioned halfway between 0.0001 and 0.0002
Hence I call it 0.0001414
Virtual Slide Rule
jpanhalt
Joined Jan 18, 2008
11,087
I must have been asleep earlier. The range to consider here is not 1 to 10, but rather 1 to 2. I agree the answer is 1.4142... for the half way point.
John
jpanhalt
Joined Jan 18, 2008
11,087
The value exactly halfway (as discussed above) between 1 and 2 is 2^1/2 . My earlier error was a brain lapse, and I was considering the range between 1 and 10.
John
