Does this code give correct data. from DS18B20
FroceMaster
Joined Jan 28, 2012
708
Code is working, but now when itøs getting hotter, i have a feeling it's not gererating correct.
Some fresh eyes will be good.
Code:
unsigned char reset(void)
     // return ONEWIRE_ABSENT; // check
    Tx_18B20;
    Port_18B20 = 0;
    __delay_us(DS18B20_RESET_PULSE);
    Rx_18B20;
    __delay_us(DS18B20_WAIT_TIME);
    if (Port_18B20 == 0)
        return ONEWIRE_PRESENT;
    else
    {__delay_us(DS18B20_RESET_PULSE);
void write(char WRT)
    char i,Cmd;
    Cmd = WRT;
    Rx_18B20;
    for(i = 0; i < 8; i++)
        if((Cmd & (1<<i))!= 0)
           Tx_18B20;
            Port_18B20 = 0;
            __delay_us(DS18B20_PULLUP_TIME);
            Rx_18B20;
        else
            Tx_18B20;
            Port_18B20 = 0;
            Rx_18B20;
unsigned char read()
    char i =0;
     result = 0;
    Rx_18B20;
        Tx_18B20;
         Port_18B20 = 0;
        __delay_us(1);//DS18B20_PULLUP_TIME);
        Rx_18B20;
        __delay_us(2);
        if(Port_18B20 != 0)
            result |= 1<<i;
    return result;
void laestemp (void)
    oldtemp=now;
    if(reset()==0)
            write(Skip_ROM);
            __delay_us(10);
            write(Convert_T);
            __delay_ms(DS18B20_CONV_TIME);
            reset();
            write(Skip_ROM);
            __delay_us(10);
            write(Read_scratchpad);
            //reset();
            lsb = read();
     msb = read();
     TReading = (msb<< 8) + lsb;
     SignBit = TReading & 0x8000;  // test most sig bit
     if (SignBit) // negative
         TReading = (TReading ^ 0xffff) + 1; // 2's comp
     Tc_100 = (6 * TReading) + TReading / 4;    // multiply by (100 * 0.0625) or 6.25
     Whole = Tc_100 / 100;  // separate off the whole and fractional portions
     Fract = Tc_100 % 100;
     if (SignBit) // If its negative
     // do things negativ ADD 5000 to avoid negative
                now= 5000-((Whole*100)+Fract);
     else
     { now=5000+((Whole*100)+Fract);
    } // end temp read.
as write , the code working, but not sure when hot >22 degree
