Does anyone know how to wire this 4 digits 13 segment display?
Guohong Xu
Joined Apr 21, 2019
Thank you for reading my post.
I have this 4 digits 13 segment display which I wanted to use it as a count down but I can't find any information about how to wire it and use it.
Thanks in advance and your time.
35,079
If it is an LED display, take a 5-9VDC supply, a 1kΩ series resistor and start probing every pair of contact in both directions.
Eventually, you will find:
1) The common pin for each of the four digits
2) Whether it is common anode or common cathode
3) The connection for each segment and d.pt.
Wolframore
Joined Jan 21, 2019
2,619
I can help a little and point you in the right direction. The manufacturer is LiteOn. They make a lot of LED products. I couldn’t find this in an active list. You might want to contact them directly for a datasheet. Basically it’s similar to below diagram you need to first determine whether it’s common anode or common cathode. Btw you have a 16 segment display. 14 plus clock points.
