Do we need to be concerned with power factor?
38,762
An interesting way to correct the power factor in plants with many large motors is to have some of the motors synchronous types and run them with high DC rotor field current so they are over excited. This gives the motor a leading PF which then compensates for the lagging power factor of the induction motors.
GetDeviceInfo
Joined Jun 7, 2009
2,284
The implications of PF depend largely on the systems capacity. The contribution of high AC demand during hot weather has brought systems down, that were already near capacity. Systems that are loaded lower than capacity have little care for poor PF.
You know going forward, that as further demands are placed on aging systems, that PF will play a larger roll.
bountyhunter
Joined Sep 7, 2009
2,512
Long known solution, even back in the 70's when I was in school. Some big factories would have huge synch machines running just for that purpose, but they were expensive so not typical that the savings on the electric bill would justify that.
AfdhalAtiffTan
Joined Nov 20, 2010
120
I believe it wouldn't hurt to improve PF.
PF doesn't necessarily means for only inductive loads.
Specifically in where I live in, excessive use of cheap CFL with low PF really gives negative impact.
That's why I'm asking earlier about running CFL on DC SMPS with APFC.
