Do inductors interfere with active components? (or any component)
Ross19892018
Joined Dec 26, 2018
32
I am building a circuit and wasn't sure if I should separate any of the components such as the inductors and the active components (transistors) so the inductors don't interfere with any operation. Does this matter with through-hole designs?
Thanks
Ross
AlbertHall
Joined Jun 4, 2014
12,626
The principle component that an inductor will interfere with is another inductor. Toroids, and coils enclosed in a ferrite bobbin have low external fields and low susceptibility to external fields and so need less care.
Ross19892018
Joined Dec 26, 2018
32
Ok great. So I’m guessing depending on the size of the inductor you will need to have a certain amount of separation between them. I have the following inductors in the image, will they be ok having a gap between of a couple of holes on a veroboard/strip board?
DickCappels
Joined Aug 21, 2008
10,661
Those are bobbin inductors -they are practically self shielding. Just do not stack them end-to-end and you should not have any problems. If you happen to be using them in a small signal application, then a little separation, maybe the diameter of an inductor should probably be enough.
kubeek
Joined Sep 20, 2005
5,796
You can also point the inductors in different directions, such as one standing, one laying on the borad, and thrid one perpendicular to both. That should give you good independence even when they are close together.
atferrari
Joined Jan 6, 2004
5,012
If those inductors are those you approach your hands to, it would be not practical. If IIRC all, even the original one, had them in line in the same position.
38,528
Magnetic fields from inductors generally do no directly affect other active or passive components, except other inductors, but that can induce small voltages in adjacent trances and wires which can be a problem in circuits with low level, sensitive signals.
Ross19892018
Joined Dec 26, 2018
32
Hmm interesting.. so if the fields are aligned with each other they can interfere
