I am trying to build a powerful and not lethal high voltage arc lighter. I revisited the project and have not had much luck. A simple relay circuit worked, but it was not practical or efficient at all. I made a MOSFET circuit with a shunt and LM358 op amp. It sort of worked but often the fets (IRFZ44N) would heat up way too much and fail. Maybe there was also inductive spiking. Well, regardless, I had to replace them like fuses. It also didn't seem to work too well with the flyback diode. I got two seconds of arcs powerful and then it failed. If I was lucky. It was about 15V and 4A.
Then I got a mosfet, 500ohm pulldown resistor, and arduino. I did a frequency sweep. It made a sound, but no arcs or significant output power. Still pretty cool (not what I was going for though). I also tried fixed frequencies up to 120kHz.
https://photos.app.goo.gl/2hyzPxoCnPNdnxVA7
The primary voltage stayed around .6-.7V (DC measured on my meter). But it did seem to show some switching too. So I am wondering if the reverse recovery of my diode is an issue. And I tested the transformer after, and it made some arcs when briefly applying a DC voltage to the primary (caused by inductive spiking). Yes, I am sure the diode was reverse biased. It is a 10A silicon diode.
