DIY tachometer for cnc spindle
rotccapt
Joined Jul 30, 2016
13
Im sorry if this is in the wrong forum please move it if it needs to be moved.
I am working on a tach for a cnc spindle i am making. I am trying to make a ready made unit that is designed for the rc industry that is used to plug in parallel to the hall sensor for an electronic ignition unit. So i am having trouble trying to figure out what i need to do to make the tach work without the ignition unit.
So the tach is rated for 3.3v to 12v dc. I will be running it on 5v. My trouble shooting thus far has been taking voltage readings to try and figure out what is going on. If i hook the tach directly to the battery and sensor the tach will initialize and show 0 rpm but no mater how fast i spin the magnet over the sensor i do not get a reading on the tach if i hook it back up with the ignition everything works correctly.
so with the ignition unit powered by a 4 cell nicad:
v+ is 4.8v
signal no magnet is 4.8v
signal with magnet is 0v
with the sensor plugged directly into the battery:
v+ is 4.8v
signal no magnet is 0.7v
signal with magnet 0v
plugging my test lead directly into the sensor lead on the ignition unit without the hall sensor i get:
v+ 4.8v
signal 4.8v
i tired applying pos voltage to the signal line but it still did not work. i think i may need an amplifier on the signal line to bring the voltage up to 5v but im not sure. thank you for your help.
Attached is a pic of the unit i am working with
rotccapt
Joined Jul 30, 2016
13
30,754
The 16f628a is still a popular pic for starter.
It almost looks as though the output is a transistor and the collector just exits via the
Red wire, if so sure, looks like open collector.
And Yes, if NPN open collector a 10k or so from output to +ve shoould provide an output swing.
rotccapt
Joined Jul 30, 2016
13
Thank you for your help, sure enough I added a 10k between signal and v+ and it works like a charm. Do you think a 1/4 watt resister wound be ok in this situation
30,754
Are you intending to use the sensor on its own with a self designed circuit etc?
If so the device or system you are using would have to be known, but generally 10k should work, it is not all that critical.
max.
rotccapt
Joined Jul 30, 2016
13
This will be used on it's own, I will be getting the +5 volts from the battery eliminating circuit from a rc brushless motor speed control to power the tach. i will be using the tach to monitor the rpm of the spindle so i can set the proper spindle speed for the material i am cutting. I will probably make a small circuit board to pull the +5 and ground from the esc to power everything and give a place for the pull up resistor and all the connections but that is it.
rotccapt
Joined Jul 30, 2016
13
If you look at the first pic, I have a tachometer that was designed to plug in parallel with a hall effect sensor used for the ignition timing for a rc gas engine that uses a electronic capacitive discharge ignition unit. I wanted to use it on it's own to monitor the rpm of my spindle, it has a 4 character LCD on it that reads rpm x10. The problem I was having was trying to figure out how to make it work without the ignition unit. With your help I found that adding the 10k resistor between the v+ and signal wires on the hall effect sensor fixed the problem I was having.
