DIY Siren module's amplifier
dadadiouffy
Joined May 4, 2020
78
If I wanna to amplifier the Sound of siren circuit, may I connect it direct to power amplifier? or can I connect the siren circuit to the powered speaker?air raidee.jpg
Audioguru again
Joined Oct 21, 2019
6,826
An audio amplifier is designed to have a fairly low level AC input. The siren circuit has a fairly high level DC output.
The little speaker shown can be replaced with a power resistor having the same resistance and a coupling capacitor can feed an attenuator that can be the input to a power amplifier.
Some (two-transistor) siren circuits will not work without the loudspeaker, the inductance and back-EMF negative spike is part of the oscillator. So putting in a resistor in place of the speaker can give odd results. 1,000-2,200uF capacitor on a two-transistor multivibrator is pretty funny. It will be very temperature and supply voltage dependent. OP should stick to the dual 555 timer Kojak siren, it looked the best.
FDNY uses Federal Signal Q-siren 123dB at 10 feet, motor uses 100A at 12VDC! No wonder I can't sleep.
dadadiouffy
Joined May 4, 2020
78
Wow! I am a beginner not even new in electronics, I don't understand electronic concept that much, just do circuit which people did and ask advice, otherwise thanks very big for your help. I have completed all circuit I have been asking you,successfully they working.
Audioguru again
Joined Oct 21, 2019
6,826
You show a "wiring diagram" instead of a schematic. I found the original article and cropped its schematic. The schematic had a few errors and could work much louder with my modifications. The transistor had the wrong symbol and part number (it should be an NPN 2N3904.
dadadiouffy
Joined May 4, 2020
78
Oops! Luckily I did not started this project yet, I will connect your modification in wiring diagram for your confirmation, so I will go ahead with this projects
