DIY Signal Generator (As seen on DIY Hacking)
Discussion in 'The Completed Projects Collection' started by Robin Mitchell, Apr 17, 2017.
  1. Robin Mitchell
    Thread Starter Distinguished Member
    Oct 25, 2009
    858
    277
    Hi All,
    Here is a simple function generator that uses the simple LM358 opamp and can produce square waves, triangular waves, and PWM.
    Required Materials
    How Does it Work?
    The first stage of the signal generator is a VCO, which stands for voltage controlled oscillator. This VCO is made up of op-amps U3A and U3B where U3A is configured as an integrator and U3B is configured as a Schmitt trigger. When an input voltage is applied to the VCO (via RV4), the integrator U3A integrates this constant voltage which results in the output of U3A being a downward steady slope (falling edge of the triangular waveform). Eventually, the output from the integrator goes below the lower threshold of the inverting Schmitt trigger (U3B) which results in the output of the Schmitt trigger switching to 5V. When this happens, Q1 is fully saturated which results in C1 discharging (through R3). As this happens, the integrator’s output begins to rise (the rising edge of the triangular waveform). Eventually, this output crosses the upper threshold of the inverting Schmitt trigger which results in the Schmitt trigger’s output switching to 0V. This turns off Q1 and results in the integrator’s output falling starting the entire process all over again.
    The PWM waveform is generated by feeding the triangular waveform (found on the output of U3A) into an op-amp (U1A) configured as a comparator. The positive input of the comparator is connected to a potentiometer (RV1) and the negative input is connected to the triangular waveform source. When the triangular waveform goes above the voltage from the potentiometer, the output switches to 5V. When the triangular waveform goes below the voltage from the potentiometer, the output switches to 0V. By adjusting the potentiometer, the op-amp U1A will turn on and off at different levels which results in a PWM square wave.
    Each waveform source is further connected to a unity gain buffer followed by a potentiometer. The unity gain buffer prevents further circuits from affecting the VCO and the potentiometer adjusts the amplitude of the output wave. Each waveform is then connected to another unity gain buffer at the end to improve output impedance.
    Construction
    This circuit can be made using standard construction techniques including solderless breadboards, strip boards, and PCBs. Attached in the project files is the CNC information needed to mill your own signal generator including auto-levelling code. It is advised that this project is used in conjunction with a project box or casing if the intent is to build you own bench tool. The example shown here is in an open case design to show internal wiring and construction methods.
    Internal Circuitry
    Main VCO Circuit
    PCB Layout
    Frequency Adjustment
    If you find the frequency of this VCO is too small or too great, you can adjust C1 to a large range of values but remember that the frequency of this oscillator is also limited to the frequency response of the LM358. Realistically, frequencies above 500kHz are not possible unless a different op-amp is used.
    Voltage Control
    Another neat trick that you can do is to replace the potentiometer RV4 with a unity gain buffer and then connect the input of that buffer to a banana plug. Therefore, you can have a signal generator whose frequency can be controlled by an external circuit (more specifically, an external voltage). This could be used for FM generation or to create a close loop feedback where the frequency generated is turned into a voltage which in turn controls the VCO.
    ScottWang likes this.
  2. DickCappels
    Aug 21, 2008
    4,355
    1,276
  3. BR-549
    Sep 22, 2013
    3,320
    822
    What does the front panel look like?
  4. Robin Mitchell
    Oct 25, 2009
    858
    277
    @BR-549 I am adding it to the main post
  5. BR-549
    Sep 22, 2013
    3,320
    822
    What is the circular object on the right side of front panel?
  6. Robin Mitchell
    Oct 25, 2009
    858
    277
    @BR-549 A horribly mounted switch :oops:
    BR-549 likes this.
  7. Wendy
    Mar 24, 2008
    21,130
    2,834
    What software did you use for the PCB?If I were functional I would offer to 3D print a box.I am out of commission for possibly years. Sorry.
    Robin Mitchell likes this.
  8. Robin Mitchell
    Oct 25, 2009
    858
    277
    @Wendy
    I used KiCad to design the PCB and Mach3 to mill it. That is a lovely offer on the box and I will definitely call on your fab fabbing skills once you get better ;) !
