DIY Project - Guitar Amp
THRobinson
Joined Jun 7, 2018
82
Hey guys... I'll start by saying I have the absolute most basic knowledge of electronics. Also, I'm long-winded and type a lot... sorry.
I was on the DIYAUDIO forum getting some really good feedback and input regarding the project, but, kinda hit the point where I needed to switch to a forum like this to stick it all together.
Basically, I wanted to build a guitar speaker cabinet, but instead of needing a head or amp attached, I wanted it to be a powered speaker and using a relatively non-coloured speaker. I have GuitarRig on an old laptop and wanted to connect it to the cabinet and use as a modelling amp so, wanted the sound of the speaker to be as neutral as possible so doesn't interfere with the modelling of the laptop.
Learned a lot about amps that I didn't know... was going to buy a 50w mono amp off ebay, recommended power supply and done... but now know about distortion/clipping and how ohms affects watts/power and overall watts depend on volts of the PSU etc. Also, probably need a pre-amp.
Goal is about 40-50w power before distortion/clipping. So about 30-32v on an 8ohm speaker, or around 24v with a 4ohm speaker. Probably the latter because price seems to jump up a bit to find one that handles a 32v PSU and the PSU itself jumps up.
Also looking at a preamp, 12-35V NE5532 Preamplifier Board for example.... and maybe cooling fans. Which is where I'm starting to have questions.
1) How to get power to the Preamp. Do I just run 2 pairs of wires from the same PSU? Do I get power off the amp board? Do I need a 2nd PSU?
2) How do I add a master volume? In the end I want 3 sets of input jacks, 1/4", 3.5mm and RCA... plus 1 master volume. I think some preamp boards have a volume, not sure if better to buy one with it, or maybe attach one to the amp somewhere?
3) How do I drop the power down? In addition to the preamp, depending which direction I go I may want to add a cooling fan for the amp and one for the PSU... but if the PSU is 24v or if I use 32v, I'd need to drop the power down to 12v... and again, just split off the terminals of the PSU? I plan to use one of the metal box types with 1 set of output terminals.
Mainly those 3 questions (for now). I know basically what I want/need... just not 100% sure how to connect them together. :)
34,812
Welcome to AAC!
Here is my DIY guitar amp. Portable, runs on a 12V battery.
Uses an automotive amp with bridged outputs.
Back cover removed:
THRobinson
Joined Jun 7, 2018
82
Thanks... looks good.
I'm hoping to make mine look like a classic VOX style amp. Looking at using stuff like
Power Supply
Amp
Preamp
Speaker
Sorta... I mean, I'm still debating 24v with 4ohm speaker, or 34v with an 8ohm... if I go 34v and 80hm, I'll need the 200w amp and the speaker will be a Eminence BETA 12" that's a more natural flat speaker than the Warehouse. Cheaper too but, don't think a 4ohm option.
Just not sure how to get the power to the preamp, or where to stick a master volume. :)
also building an arcade cabinet, audio and power was much easier to sort out on that. Hoping to cut all the wood for both projects at the same time in a week or two.
