DIY Function Generator for Under $50
AlphaDesign888
Joined Jul 27, 2014
193
*Function Generator 1MHz*
Requirements:
a. Waveforms sine, square, triangle
b. Variable frequency
c. Variable duty cycle
d. Variable amplitude
e. Sweep function
f. Astable or monostable operation
g. Mains powered
h. Metal enclosure
i. Analouge schema using pots, switches and buttons
j. Can be built for under $50
How would you do this one?
alexfreed
Joined Oct 8, 2012
72
The right solution is to use a microcontroller. STM32 with built in DAC is perfect. The whole boad is $10.
If you insist on an analog solution, search for 30 years old designs around MAX038.
AlphaDesign888
Joined Jul 27, 2014
193
Actually I am thinking of something that uses many discretes.
Like a dozen or so OP AMPs.
People will learn more from this, and it will take some time to build. Lots of people like soldering boards with lots of parts.
RichardO
Joined May 4, 2013
2,270
Lots of questions...
What frequency range? You need some fairly fancy op-amps for over a few MHz of operation.
Does variable amplitude include an output attenuator? An output amplifier with 50 ohm output impedance is needed for high frequencies.
Log or linear sweep of both? Log sweep is trickier than linear sweep but it is most likely what you want.
How important is the monostable operation? By this I assume you mean trigger and gate modes?
How important it the $50 dollar limit? Pots and knobs are expensive! The metal box alone can be more than $50. :(
Maybe you should look at old Wavetek models and tell us which one you like. The model 181 is a good one to look at first.
AlphaDesign888
Joined Jul 27, 2014
193
I would compromise on whatever to meet the $50 target.
There is psychology floating around that suggests that most people think long and much harder about spending more than $30.
I have purchased metal project enclosure from Taiwan for $7.50 landed (on eBay)
Pots, knobs, buttons & switches are cheap enough through Tayda Electronics (Taiwan)
I feel something can be done for $50. A toy perhaps. But still something.
RichardO
Joined May 4, 2013
2,270
Why not use a 8038 (ICL8038, XR8038, MAX038) or XR2206?
This is what I would do. But keep in mind that all of these old parts may be, or will soon be, obsolete.
The project will still be interesting when you add all of the other stuff needed to do what you want such as an output amp, trigger/gate circuit, attenuator, power supplies, log sweep circuit, enclosure/front panel, etc.
p.s. I would go with the MAX038 The MAX038 is no longer made but parts are still available.
RichardO
Joined May 4, 2013
2,270
Here is an example of a 10 MHz function generator. It is a design I did a long time ago. Features include: variable symmetry, AM, FM, trigger/gate, a 50 ohm pulse output and a 50 ohm waveform output with adjustable DC offset.
This is the function generator I use the most although I have others including one done using a MAX038.
This is only for reference since many of the parts were expensive when I did the original design and are hard, if not impossible, to get now.
RichardO
Joined May 4, 2013
2,270
Maybe I should realize the 21st century and go with an digital system.
Just like a digital scope is not the same as an analog scope, a digital signal generator is not the same as a function generator.
Disclosure: I like my test equipment to have knobs and switches and not keyboards.
AlphaDesign888
Joined Jul 27, 2014
193
But either way it is an no winner right? Electronics has now become an situation whereas everyone just wants to do their own thing.
THE_RB
Joined Feb 11, 2008
5,438
If you are going to be making something to sell to "people" for $50 I don't think there will be any significant profit in it.
Kits sales are at all time lows in the last few years.
AlphaDesign888
Joined Jul 27, 2014
193
That's what I mean by 'no winner'
Whole thing has gone belly up. No money anywhere.
