a novice and a broken switch-mode PSU are definitely not a good match and someone is likely to get hurt.
Switch mode PSUs like these if faulty can electrocute you if you touch internal components even after the PSU has been off for a prolonged period.
I do have a vivid memory of being knocked backwards out of a television while trying to disconnect the anode connector from the picture tube. Several other devices can retain a charge, but usually not as bad as a CRT.
Capacitors can give give a nasty shock and can kill if they have enough charge.
perform safety procedures such as discharging all capacitors with an alligator lead and a 10 ohm resistor for at least 2 seconds rather than betting your life that they can't hurt you.
you've been advised not to play with it because half the power supply is at mains potential and even after unplugged has the ability to maintain a charge. even if not lethal can be very nasty.
Eventually you learn about that some day and get a puncture burn.
Only a few need caution, I always tap these with a screwdriver. If i get a bang, I know they were live.
Since you claim to be new to this, you might not know that capacitors can store a charge, just like a battery. They can discharge at the most inappropriate times causing pain and sometimes injury.
Ferden, FYI: a good cap holds a charge. There's a reason that many caps and cap banks employ resistors to act as drains when power is removed. Ignoring this fact can cause equipment damage. If the voltages are high enough, the damage can get personal, as in #12's case.
A few months ago I was working on a DVR power supply board and forgot to discharge the primary Side capacitor, needless to say it punished me for it. It's every bit as unpleasant as getting your fingers across 230vac.
I get it, really. I just said it's rare, and never more than a sparkle. I mean, no need to repeat.just can't see the point of beating a dead horse
Do you know any name?There are software utilities that can show you where power is going and what it's being used for.
Oh my, I only resist a theft. By the way, private property is a theft.Oh my. You are a stealer.
Of course I can afford it. Once. What surely I can't afford, nor 95% of humanity, is paying for a program, device or media every time a company feels entitle to ask me money for. Can you image what would be this world if I had to pay Britney Spears for every time I heard one of her songs? Quite often without even my consent?Cant you afford Windows 7 or Windows 8?
All that without saying that I certaintly don't like it when Windows imposes a new version (and asks money for it) every three years, nor that holds and enforces a monopoly, nor that it ties the sell of computers with the sell of an OS (itself, of course), nor that it identifies every piece of software, hardware, file (and even users!) with unique identities, nor that Microsoft keeps record of all of that, nor that it uses those records for its greedy and oppressive purposes, nor that you discover a new bug every day, nor the deliberate dumbing down of a software/OS so that a company can ask you money for a number, nor that after uninstalling a software pieces of it (the license info and others) still linger around on your HD, nor the systematic use of trojan and viruses once again with the goal of taking consumers' money, nor that the whole industry is fond of programmed obsolecense (I have boxes full of hardware that DO work, but of course I can't use because old and incompatible), nor that every company imposes the use of proprietary consumables, nor that costumer supports fall nothing short of a scam, nor that companies impose their fantastic view of the world to every user, like, you know, this pretty new "start" page on win8 that you can't get rid of, like those liberal links to "microsoft store" "xbox store" "apple store" "itunes" that you can't delete, like a cute little back-door to the NSA in https...).
Not to mention the mandatory use of English language, the use of countries' public resources to enforce companies' private interests, the use of countries' laws to outlaw the sanitation of protected software and, of course, the fancy new society that social networks and digital communications are shaping...
Do you want to discuss the topic a little further?!?
As for the original problem, to make a little recap: some people say it's a bad idea, even though I didn't understand why:
Pretty much guarantee that's a bad idea, a PC PSU is not a simple switch mode PSU. Standard switch-mode PSUs often can load-share but a PC PSU is a different beast. I recommend don't do it.
So the question is: why 2 PSU on 1 MB is a bad idea?Besides there is no good way to parallel them.
You can however use one for the drives with 4 pin connectors (not that I think that would be cutting it).
Also, I still don't understand the instructions I got so far:
Use second psu to power video card and maybe power the hard drives/cd rom drives.
All you need to do is to parallel the startup wire, and the ground.
That is often a grey, green or purple wire.
Yes power all the Hds with a second PSU. Do as i explained.
Which of the following setup is the correct one?I wired the secondary PSU to power on with just a slide switch by connecting the green wire from the PSU to one of the black(ground) wires with a switch. Just make sure that when powering up, to power up the secondary PSU first, then the primary.
1 - Plug the second PSU to the electricity and to some drives but not to the MB.
2 - Plug the second PSU to the electricity, to some drives and wire the second PSU pins 14 and one of 3, 5, 7, 13, 15, 16, 17 ( http://pinouts.ru/Power/atxpower_pinout.shtml ) to the MB (and by doing this to the first PSU as well).
3 - Plug the second PSU to the electricity, to some drives and wire a switch between pins 14 and one of 3, 5, 7, 13, 15, 16, 17 ( http://pinouts.ru/Power/atxpower_pinout.shtml ) of the second PSU (thus not to the MB or the first PSU).
4 - Something else.
