Greetings Enthusiasts,
This project aims to create a simple and economical diy headphone amplifier. The amplifier consists of a tone control which can cut/boost up to 5dB. The amplifier’s gain is set to 3dB to ramp up the volume a bit.
It’s my first project and am looking forward to suggestions, critics and improvements. I have attached the SPICE Simulations results and the final schematic. Some of you might argue I have simulated a TL072 OP Amp instead of the TDA1308 amplifier IC. Well, I couldn’t find a Spice directive for TDA1308 compatible with LTSPICE. I have trouble understanding PSPICE. Given that, a part of this project depends on assumptions which is why am looking forward to your advice before fabrication.
Cheers!!
Cheers!!
