DIY 9V .85A DC POWER SUPPLY SCHEMATIC
Vipul Kumar 1
Joined Oct 20, 2018
81
I hv 12V 1A DC adapter but i want to convert the 12V 1A output to 9V .85A using L7809 Voltage Regulator
Can Any one suggest me how to do this and what should be the connection diagram or schematic to achieve this result
LesJones
Joined Jan 8, 2017
4,539
Just follow the information on the LM7809 data sheet regarding input and output decoupling capacitors. You will need a small heat sink on the LM7809 as it will be dissipating 2.55 watts.
Les.
Vipul Kumar 1
Joined Oct 20, 2018
81
Les.
I HAVE HEATSINK ON IT BUT STILL HEATING
I HV A TPLINK ROUTER THAT REQUIRES A INPUT OF 9V .85A BUT DUE TO IMPROPER CURRENT MY ROUTER IS GETTING SWITCHED OFF AFTER RUNNING A WHILE
Vipul Kumar 1
Joined Oct 20, 2018
81
SIMILAR TO SIZE OF REGULATOR AND ITS A TYPE OF ALUMINIUM AND sORRY SIR I HV NO GADGET TO MEASURE THE TEMPERATURE BUT IT WHEN I TOUCH IT IT CAN BURN MY FINGERTP 10-15 SECOND
LesJones
Joined Jan 8, 2017
4,539
This is the schematic for connecting the LM7809 (Or any of the LM78 series of regulators.)
The regulator is probably shutting down to protect itself due to too small a heatsink. When you buy a heatsink it will have a rating of Deg. C/W. This means it's temperature will rise by that number of Degrees C for every watt dissipated. I would aim for it not to get above 40 Deg, C
Les.
