distorted output in class A audio amplifier
alimash
Joined Oct 12, 2016
67
hey friends
i am building my first class A audio amplifier
i achieved the dc biasing step successfully
this is my circuit:
the problem is when i connect the audio signal to the output i get a distorted signal
output signal:
i can not figure out why
what am i missing here
waiting for your replay
thank you
AlbertHall
Joined Jun 4, 2014
12,625
Look at the input and output voltages you now have. The output voltage divided by the input voltage gives you the gain of your amplifier. Your original circuit had a 1V input so multiply that by the gain and that is the output voltage your circuit was trying to produce but it only has a 12V supply voltage.
Veracohr
Joined Jan 3, 2011
783
C3 is bypassing the emitter resistor so the emitter resistance for AC is only about 25 ohms (25mV/1mA). The gain is then 6800/25=272. Too much for the input/power supply voltage.
BobTPH
Joined Jun 5, 2013
11,515
Well, you fix works, if what you want is an amp with a gain of 4.
There was nothing wrong with the original circuit. It is just that it had too much gain for the input signal you were giving it. If you had reduced the input signal as suggested it would have worked as well.
Bob
Wendy
Joined Mar 24, 2008
23,798
My 2cents ,too much gainin the circuit.Look closely at the emitter capacitor. It is boosting your gain to max,
