Disk drive control
ksquare
Joined Oct 11, 2009
17
Can anyone point me to info on how to control a computer disk drive? I just want to spin the drive and move the heads around. Nothing more.
Irving
Joined Jan 30, 2016
5,109
SATA or IDE interface? I assume you're not interested in accessing the data, just the mechanical functions? Neither interface gives direct control of the head positioning. Drives are treated as a contiguous stream of 512 byte blocks and the command protocol just requests a starting block and number of blocks to read and the drive does the rest. IDE would be much simpler interface, 16bit parallel I/F and a write pulse
Of course, if you want to access the mechanism that drives the head position you'll first need to figure out what type of mechanism it is, as various methods have been used.
https://allpinouts.org/pinouts/conn...a-sata-serial-advanced-technology-attachment/
https://pinoutguide.com/HD/AtaInternal_pinout.shtml
ksquare
Joined Oct 11, 2009
17
Thanks for the links Irving. Yes just interested in the mechanicals and primarily IDE. I don't want to read or write, only position head which I think is called seek. For arguments sake assume the drive has 1024 blocks. If the head is at 512 and I want to read block 1024, does the drive have to be told the starting block is 512 and the number of blocks to read is 512 or does it use that info to calculate getting to block 1024 for the read? I assume the latter which would mean in order to get where you want to go, you need to know where you currently are. In that case, if one is lost there must be a way to reset to a known position? I've looked at a few drive datasheets but they don't cover this stuff.
Irving
Joined Jan 30, 2016
5,109
I'm not au fait with the detail, but the whole point of the Integrated Drive Electronics (IDE) is that the host didn't need to know anything about the internals of the drive, only how big it was. So the drive maintained its internal state, and, say if the drive was on block 512 and you asked for block 200 it worked out how many tracks to move back and then how far round the disk block 200 was. I think there was a command to retract & park the heads.
AFAIK there was no direct control of the motor. It span up when powered on, and stayed on.
@sagor thanks, I was looking for that project, I knew from memory someone had done it with an MCU
Here's a few more:
https://github.com/Manawyrm/ATAPIMega
https://hackaday.com/2021/01/03/an-arduino-and-a-cd-rom-drive-makes-a-cd-player/
http://singlevalve.web.fc2.com/Atapiduino/atapiduino.htm
