Directional current flow AC Current Transformer howto
Thylacine_Tim
Joined Oct 3, 2011
I have a grid connected solar inverter and want to get an indication of when I am exporting or importing power.
I understand how current transformers work and think I could use one only problem is it would only give me flow not direction.
It is doable as power diverters are available. Any advice will be very appreciated.
AlbertHall
Joined Jun 4, 2014
12,653
You could compare the phase of the current waveform with the phase of the voltage waveform to derive the real power. The sign of the real power will reverse between importing and exporting.
Thylacine_Tim
Joined Oct 3, 2011
You could compare the phase of the current waveform with the phase of the voltage waveform to derive the real power. The sign of the real power will reverse between importing and exporting.[/QUOT
Thanks for your reply AlbertHall. I will have to do a bit more research on this.
