Direct-Coupled CE Amp - Voltage Gain?
aac044210
Joined Nov 19, 2019
178
Here is a little gem that I found on line. A direct-coupled CE amp.
I calculated the voltage gain for each stage and for the amplifier overall.
The overall gain is 11,320 and yet LTS results in a gain of 350. 99% of
vs enters the first stage but I can't figure out why the gain is so low.
Any suggestions?
ericgibbs
Joined Jan 29, 2010
21,550
hi aac,
Do you have a link to the online circuit, RE2 looks a high value..
What did your maths say for the gain of the 1st stage.??
E
Jony130
Joined Feb 17, 2009
5,598
Well, let me try.
From LTspice we know that Ic1 = 323μA and Ic2 = 423μA
The second stage gain is Av2 ≈ 38*Ic2 *Rc = 38*423μA*10kΩ ≈ 160 V/V
And the input impedance of a second stage is Zin2 = β/gm = 300/(38*423μA) = 18.66kΩ
The first stage gain is Av1 ≈ (Rc1||Zin2)/(RE1) = 2.1 V/V
Hence the overall voltage gian is Av = 2.1*160 = 336 V/V
aac044210
Joined Nov 19, 2019
178
Jony130
Joined Feb 17, 2009
5,598
But lack of this capacitor is the reason why your calculation does not match the LTspice result.
Because without this capacitor (Ce1) the first stage gain is very low Av1 = (Rc1||Zin2)/( RE1+re1 ) compare to the situation when you include this capacitor Av1 = (Rc1||Zin2)/re1
aac044210
Joined Nov 19, 2019
178
If you put the RE1 bypass cap into the circuit, the gain is nuts and the amplifier is useless.
Why would they even show such a circuit?
I have re-calculated my gain as attached.
aac044210
Joined Nov 19, 2019
178
Well, let me try.
In your Av2 calc where did the "38" come from?
Why does Av2 = RC2 / r'e2 not work?
aac
