Diodes in series parallel
GJorf
Joined Jan 27, 2022
6
Hi, I need a little help understanding why there are two sets of three diodes in series parallel and what the resistor in parallel with the diode is doing and the capacitor at the bottom. Thanks in advance.
Papabravo
Joined Feb 24, 2006
22,099
It is essentially a low pass filter that turns the square wave output of the oscillator into a piecewise approximation of a sinewave.
Papabravo
Joined Feb 24, 2006
22,099
Thanks for the response. But, why use so many diodes?
It's a pretty crude approximation, more would be better. Thing of a sine with 3 steps up and 3 steps down and then the reverse. It would look kind of ugly on scope but maybe(?) sound acceptable(?).
sparky 1
Joined Nov 3, 2018
1,218
Take 6 diodes with increasing and decreasing resistors. Each diode's resistor corresponds to a voltage at each point on the Y axis of an oscilloscope
that is:
If you divide a complete sine (360 degrees) by 6 divisions and plot the points and connect the points with straight lines you have a a piecewise approximation of the sine made of 6 segments. The more segments the smoother the line or the better the flow. The capacitor gradually stores a charge from which a sample can be taken.
GJorf
Joined Jan 27, 2022
6
Thanks for all the info. Just one last question, can you explain what the resistor does in parallel with the diodes?
Papabravo
Joined Feb 24, 2006
22,099
When the diode conducts the resistor is "shorted". When the diode does not conduct, the resistor provides a current path.
