Diode vs Transistor Opto isolators
s200bym
Joined Aug 9, 2017
82
Other then one is a diode and the other is a transistor, I am trying to understand the differences between the 2 types of opto isolators. and how you would go about using them in your circuit. What would pin B be used for?
Cheers,
Mike.
mvas
Joined Jun 19, 2017
539
Two differences are:
a) Speed
b) The Current-Transfer ratio.
The (B) Pin = Base is use to control the Gain / reduce noise sensitivity
Resistive Optocouplers
Photo Diode Optocouplers
Transistor Optocouplers
Darlington Optocouplers
Diac Optocouplers
Triac Optocouplers
SCR Optocouplers
Select the appropriate optocoupler for the application
