Diode parameters
Rufinus
Joined Apr 29, 2020
325
Hi everyone.
I have a theorical question about using a diode in series with a resistor.
Let's say I have a AC source of 100V and connected to it I have a string of 10 resistors in series, each one of 1k. In each resistor there would be a voltage drop of 10 volts. Now I add one diode In series. What should be the max reverse voltage of that diode?
I mean, if it is just the diode connected to the AC source should be at least 100v. But since it is a diode with a string of resistors I'm not sure. It is just a theorical question, I'm not looking to apply to anything, I'm just curious about that.
Thank you. Best regards
35,309
Hi everyone.
That's a very good question.
The answer is 140 V.
38,952
The 10V is only dropped across each resistor when the diode is conducing current in the forward direction.
In the reverse direction there is no significant current so no voltage drop and the full AC peak voltage appears across the diode.
Rufinus
Joined Apr 29, 2020
325
Thank you for your answers.
Yes, I forgot to mention it is was peak voltage or RMS.
In any case, now is clear. But a new question came to my mind. Lets say is a DC power source of 100V and it is connected just in foward direction, what should beparamters of that diode?
Thank you
35,309
Thank you
If the diode is always forward biased, the maximum reverse voltage of the diode does not matter.
WBahn
Joined Mar 31, 2012
33,353
Hi everyone.
In "theory", a diode has no max reverse voltage -- it is a theoretical component which conducts current when forward biased and blocks current when reverse biased. So the question has to be considered from the "practical" side of the house. So there are two questions -- what is the maximum reverse voltage that the diode sees, and what is the minimum reverse voltage that the diode should be rated for.
If the diode has negligible reverse leakage current, then when reverse biased there will be negligible current in the resistors and, hence, negligible voltage drop across them. Therefore, all of the voltage will be dropped across the diode. If 100 V is the amplitude of the AC source, then the peak reverse voltage seen by the diode would be 100 V. On paper, you need a diode that has a minimum reverse voltage rating of 100 V. In practice, using such a diode would be risky. A common rule of thumb for many things is to use a safety factor of at least two wherever practicable, so use a minimum reverse rating of at least 200 V. Where a factor of two isn't practical, proceed carefully.
Rufinus
Joined Apr 29, 2020
325
Thank you all.
No real purpose crutschow , I just was curious, I´m learning electronics and I like to understand everything. But now everything is clear. As always in this great forum
