Diode on the base of BJT.
ScottWang
Joined Aug 23, 2012
7,504
The diode is using to protects the b,e diode of bjt when there is a negative voltage appearing on the input, normally if the input voltage as +V, 0V, -V and the circuit only needs the 0, +V, so you need to cut off the negative voltage, if the input voltage only with +V, 0V then you don't need the diode.
evandro bubiak
Joined Aug 4, 2015
12
To prevent the base emitter junction from being reverse biased sufficiently to breakdown the junction. That would kill the transistor beta.
Thank you! Understood!
