Diode Identification Help
sagor
Joined Mar 10, 2019
1,055
Really need a bit of a circuit or picture of the board where that diode came from. It may be a standard type of 1A diode, or it could be a zener diode, like a 1N4135 (100V zener). A 1n4135 zener is a small diode, about 2mm in diameter (0.08 inch) +/- a bit.
sagor
Joined Mar 10, 2019
1,055
I suspect it must be the same as D64, look at that one for more markings, if it has any. Otherwise, I've venture to say it is a standard 1n400x series of diode.
sagor
Joined Mar 10, 2019
1,055
That may be a date code. The second line also has a "35" on it, I suspect that is the actual part number, since the "35" matches your other diode.
