Hi all!
Last month I bought a pair of Denali DR1 Auxiliary motorcycle (single intensity) LED lights http://www.twistedthrottle.com/denali-dr1-single-intensity-led-auxiliary-lighting-kit-with-full-wiring-harness-m8-mount before realizing that the whole line of Denali 2.0 lights were coming out within a few weeks. A main feature between the 1.0 and 2.0s is dimming. The 2.0 harness features dimming capability that is (of course) not compatible the original harness or 1.0 lights.
I have read many posts on people dimming Denali single intensity lights with ADVmonster LED dimmers http://stores.advmonster.com/rotary-led-dimmer-with-high-beam-bypass/. This unit accomplishes dimming through PWM.
In this webBikeWorld review of the ADVmonster rotary dimmer, the author claims to have successfully hooked the dimmer up to a pair Denali lights via the electrical harness that came with the lights. In this setup, both the original ON/OFF power button works as well as the dimmer. http://www.webbikeworld.com/lights/motorcycle-led-dimmer/
I decided to buy the ADVmonster rotary dimmer. I hooked up the dimmer exactly the way review on webBikeWorld says to (hooking pos. and neg. lines from the dimmer to each light, and then splicing into the main power up right before the 5 amp fuse on the harness). On this setup the lights stay continuously on and are not able to be turned off except by removing the positive line from the dimmer to the main power before the fuse. Next, I tried to splice the power line from the dimmer into the ON/OFF button's pos. line right before it goes into the relay, but am still not able to dim.
I am not sure what to do next. I know that this is simple wiring and I should be able to hook up the dimmer while using the Denali electrical harness at the same time. I have included diagrams of the Denali wiring harness with my 2 setups. Any and all thoughts are greatly appreciated. Thanks!
