I would say, it is possible. However, I don't think it is safe. What prevents anyone from adjusting the dimmer once you install the non-dimmable LED?Can I connect non-dimmable LED's to a dimmable LED driver? I do not intend on using a dimmer. Just a switch.
The LEDs could not have died and then worked later. I must assume the LEDs did NOT die, they just stopped making light. Now that we have stopped believing the LEDs are dead, it's time to turn attention towards the Driver. What do you have for a meter? Can you measure volts and milliamps?The first time I connected the LED's they flashed briefly then died. I then connected a boost converter to the same string and all the LED's worked.
This idea is a bit difficult too, considering the Thread Starter said,Turn the dimmer control down to about half way and get the LEDs working, then crank up the dimmer control a bit.
andCan I connect non-dimmable LED's to a dimmable LED driver?
I'm trying to make an aquarium light with a simple on\off switch. No dimmer.
Specific part numbers or data sheets would be helpful.Can I connect non-dimmable LED's to a dimmable LED driver? I do not intend on using a dimmer. Just a switch.
Will the constant current circuit CAUSE 300 mA to flow or just limit it to 300 mA. Could sticking in a resistor bring the current down to 250 mA?Because the LEDs still work after connecting them to this power supply, that the power supply is shutting down rather than LEDs getting damaged.
The supply is 300mA constant current and can supply that constant current (stay in compliance) over the stated voltage range. Note that higher voltage loads will be easier for the power supply to maintain compliance and it has to dump more energy as heat when supplying a load closer to the bottom of the acceptable output voltage range. Again I am guessing without a datasheet but your power supply cannot really handle loads with such a low voltage when really designed for 50+ volts.
I would either add more LEDs in series (notice that it stayed on a bit longer when you did do that - be for it overheated), or, you can try to force the voltage drop outside of the power supply with a dropping resistor. Let a resistor drop 30 volts at the rated 300 mA. That can simply be a 100 ohm 10 watt sand-bar (100 ohm x 0.3A = 30V).
Good luck
Apologies if my terminology is a bit vague or just plain incorrect. With all the help and suggestions I'm getting I'm learning fast though. I have a no name brand digital multimeter and I have managed to measure both volts and milliamps through the circuit. but only when I used the boost converter which kept the LED's on long enough for me to measure. Below is a screen shot of the driver.I'm thinking either you don't have 1 watt LEDs or you don't have a LED driver that works.
This part is difficult to interpret:
I did have a fleeting moment of thought and tried a 1ohm resistor in series but still no cigar.Will the constant current circuit CAUSE 300 mA to flow or just limit it to 300 mA. Could sticking in a resistor bring the current down to 250 mA?
Good luck
(DIY Aquarium LED expert here..built many fixtures)
Those "ARE" dimmable LEDs..
Your diagram is wrong.. The LEDs are shown backwards.. The + output from the driver should go to the + of the first LED
What are you attaching the LEDs to? do you have a circuit board?
What are you doing for heatsinking? You can quickly overheat and destroy the LEDs if not heatsinked properly..
