Dimmable capacitive touch
jacket_potato
Joined Feb 11, 2020
Could someone please point me in the right direction.
I'm trying to make a capacitive touch lamp, that you simply move your finger up/down to change the brightness of the led's.
I first looked into using an arduino and taught myself the very basics. I thought because of the coding involved I could make it do what I was after, not so sure now.
Is there a module out there that would be more ideal?
dl324
Joined Mar 30, 2015
18,449
Welcome to AAC!
To do that, you're going to need something like a touch screen. I have a commercial touch dim fixture and it changes brightness based on how long the lamp is touched.
KeithWalker
Joined Jul 10, 2017
3,615
The simplest solution would be to use two touch sensors. One for up and one for down. The brightness would change depending on how long the sensor is touched.
Keith
KeithWalker
Joined Jul 10, 2017
3,615
An alternative would be a single sensor with the brightness increasing in steps in a repetitive loop each time the sensor is touched
Keith
