Digitalise Lightning Consoles
Okaghana
Joined Jan 14, 2017
9
Following Situation....
We have a Lightning Console to controll our stage lamps and we thougt to digitalise it and use a laptop.....
The Console is a Zero 88 Sirius 24 and it's connected with an RS-232 25 pins.
Is there a way to digitalise it ???
P.S. If we would do it, we would also need a corresponding Software
P.P.S. Upgrade our system to better hardware is not an option.
djsfantasi
Joined Apr 11, 2010
9,237
Wow! There's not a lot to go on there. I would guess that the presence of the RS232 jack gave you hope. Have you searched for s manual or schematics? They would be necessary..,
If you have not found a source for software (I assume you have looked), you will likely have to write it yourself. Or get someone to write it ($$$).
Not knowing how the console talks to the world, writing software will be difficult if not impossible.
We need much more information in order to help. You need to get that info.
Okaghana
Joined Jan 14, 2017
9
Well....
You can download the manual here
I assumed that it would be very difficult and I don't think that it will work, but I wanted to try it.
I found a software from Zero88, but for a newer version.
What Information do you need?
