digital electronics
seded
Joined Oct 31, 2019
Which of the following statements are true? Check all that apply.
1.In a Read/Write memory, bit-lines transmit the information to be stored in memory cells, while word-lines transmit the Read/Write command.
2.A 220 x 16 words memory has a 16-bit data bus and a 220-bit address bus.
3.A 220 x 16 words memory requires a 20-to-220 address decoder
4.DRAM basic cell has fewer transistors than the SRAM one and therefore, DRAM memories may have a larger storage capacity than the SRAM memories.
5.DRAM memories retain information even when no power is supplied because they incorporate circuitry that periodically refreshes the information.
6.OTP ROM can be programmed up to 128 times.
Ya’akov
Joined Jan 27, 2019
9,164
Welcome to AAC.
This topic is here to help with homework, not to take exams for you.
If you need help with this question, you will have to show what work you have done to solve it, and people will give you advice on how to proceed to work it out on your own.
You won’t get help with this post as it stands.
ci139
Joined Jul 11, 2016
1,898
