Digital coax cable?
38,797
There is no specific difference between "digital" and "analog" coaxial cable. The coax doesn't know or care what type of signal it is. The main characteristic of interest is the maximum frequency content of the signal and the attenuation factor of the coax for those frequencies.
It's the same type of hype that is promoted for "digital" TV antennas. "Digital" antennas are no different then the standard "analog" antennas. It's the frequency of the RF signal being received that determines the antenna design, not the type of modulation carried by the signal.
electronewb
Joined Apr 24, 2012
260
So what can cause some frequencies to have more attenuation than others?
I can see that the attenuation is higher with the 1505A but is it due to the size of the center conductor?
mcgyvr
Joined Oct 15, 2009
5,394
Its mostly due to the density/size of the dielectric between the center conductor and shield. Less density = less losses
electronewb
Joined Apr 24, 2012
260
Interesting so basically they should make all coax cables with less density? Why ar ell those frequencies tested for attenuation? Is it for multiplexed signals?
Some cables are designed for power transmission, some are designed for lower loss and other factors. The characteristic impedance of the cable is set by the inner conductor size/spacing and the dielectric constant of the inner insulator so 'less density' is not aways better when size is a important factor. For air the minimum attenuation is at about 75-77Ω for a coax, for other common dielectrics the minimum attenuation is at about 52-64Ω so 50 and 75Ω cables are usually used with RF. With high-speed digital signals it's common to see higher impedance cables (rg-62/63 cable) used to reduce load capacitance and improve rise times with current limited drivers.
http://www.rfcafe.com/references/electrical/coax-chart.htm
http://www.prioritywire.com/specs/c-4.pdf
electronewb
Joined Apr 24, 2012
260
Speaking of... what is the Ω represents in a cable? Resistance that the center conductor represents like a resistor or it's more complex than that?
38,797
It is the characteristic impedance of a transmission line. It is mainly determined by the distributed capacitance and inductance of the line, and for an ideal lossless line it is Z = \(\sqrt{L/C}\).
If you apply a step voltage source to an infinitely long transmission line, the current drawn from the source will equal V/Z.
