Digital Clock Using Gates
ryandezz
Joined Dec 4, 2010
4
i'm building a circuit using this diagram,is there any problem with the circuit above?i realised there's a frequency generator needed for pin 6 of the multiplexer...is there any way i know what frequency to insert in there?and if i were to replace it with a 555 timer,how would i do it?Any suggestions are most welcomed,i want to try to do this circuit.thank you in advance!
edgetrigger
Joined Dec 19, 2010
133
i don't see any circuit. pls reload it.
half sec pulse or 1 sec pulse will serve as a clock source, and 555 is good enough for this job.
hgmjr
Joined Jan 28, 2005
9,027
You can use a 555 but only if you are not interested in maintaining accuracy. For accurate time-keeping you will need to use a crystal oscillator. Many solutions use a 32768 Hertz clock that is divided down to 1 Hertz.
hgmjr
ryandezz
Joined Dec 4, 2010
4
the link to the diagram is this>> http://img171.imageshack.us/i/ttlclock2ug7.png/
how would i connect it using the 555 timer? i've searched around but i dun really understand the diagram such as stated in this link
http://forum.allaboutcircuits.com/showthread.php?t=28974
i notice one of the pin on the 555 timer has the frequency symbol....does it mean i need to connect to the frequency generator?
and do i need to consider connecting to the other ic's?how can i do it?all your feedbacks are greatly appreciated!
Wendy
Joined Mar 24, 2008
23,860
The imageshack link is unreadable, the resolution is just too low to make out any details.
A better AAC link would be something like this, I drew it up for beginners in logic.
There are many chips that will plug into the boxes shown on this block diagram, many.
A 555 is low accuracy, it drifts. A crystal oscillator is much more accurate, and is what most digital watches use.
Quick note, this site has its own albums, it is a lot easier to use the local albums for posting pictures that an outside website.
Another good website that may have what you want is Bowden's Hobby Circuits. It has several schematics of various digital clocks.
